Exhaust - Welding
G1989
Recommended Posts
Well couldnt post in tech help so thought this would be the next best place.
Was wondering if anyone has any tips on how to weld a stainless backbox to the stock exhaust system on the felicia (guessing is just normal mild steel) Now i know theres gonna be problems trying to weld the 2 so wondering if anyone got some good ideas :thumbup:
Thanks in advance!
*edit* the problem is welding the 2 metals btw in case u dont get what im chatting about :P
Link to comment
Share on other sites
If you have access to a TIG welder then it's easy enough with the right skills.
I would used a stainless filler rod and keep the heat down to a minimum. Mig is possible but to get the right amount of penitration and control is easier rather than controling the weld pool and getting a feel for the metal as you go along.
Hope thats not too technical, welding looks easy but is a bit of an art form and take practice to do right.
Link to comment
you could weld them together but it wouldn't be easy, it's beyond the skill of most welders to be honest...
first question what is the diameter of the two pieces you are joining?? is there a miss-match in size
Havnt had the chance to look, i pretty much bought it off the shelf. Been raining ALL day today so havnt been able to get under and check it out. Im not much of a welder so i guess it will have to be a specialist job :thumbdwn: Was worth a try anyway :rolleyes:
Ill let you know what happens anyways and maybe get some piccys of it :thumbup: why not eh:cool::D
Link to comment
:+1: - When I read "welding an exhaust" I thought "repair work, stainless -> TIG". I'd expect a stainless box that was designed for the car to just slip on at the designed joint on the mild system, and the most I'd expect to need if the box was designed for a "sports system" on a Felly would be an expander.
Link to comment
back pressure:rofl:
this is no adjustment for back pressure as such, but the ecu will make sight adjustments based on the lambda reading, but to be honest fitting a 'special' back box wont make any difference because it's too far away from the engine
Link to comment
You might laugh Tom, but I've driven an oldish carbie TU car that was very sensitive to drops in back pressure caused by holes in the exhaust, and a newer SPi one that didn't notice beyond the increase in exhaust noise when the system broke at the cat outlet!
Link to comment
Well been to a few garages that didnt really want to take the job on :rolleyes: not suprised really, but going to a garage tomorrow who said they will take a look but they charge 48.50 labour per hour :eek:
Here is the backbox.....
Note im not going for performance :thumbup: Just looks :rolleyes: and sound :thumbup:
Also, first time ive ever fitted a performance air filter too, gotta say im super pleased with it. Really big difference in my throttle response. Cost me £50 from P&B Motorsport (Local) makes a great sound too.
Edited by G1989
Link to comment
that aint gonna go in there, it's far too big
Crap :rolleyes: I thought so, oh well can always ebay it :thumbup:
Edited by DGW
Non-Freedom advertising.
Link to comment
if you show some pictures of it with a tape measure next to it it would be handy so i can get an idea of exactly how big it is....
the real problem lies with the clearance between the rear trailing arm and the spare wheel recess in the boot that protrudes down,
Link to comment
No worries, but i will have to do it a bit later on if thats ok? What bits did you want measured?
Link to comment
The Ask a Tech forum is one of the perks for Freedom members, along with advertising for free on Briskoda.
Link to comment
"Pay £12 and advertise as much as you like for a year" - this is cheap certainly, and I'm not claiming otherwise, but it's a new definition of "free", one with which I have not previously been acquainted!!:rolleyes:
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
