How to determine the maximum safe power output for an AUQ?
G-slave
Recommended Posts
TTs that have different turbo's manifold etc
180 TT's are the same engine code as the vrs (AUQ) 225 tt's are the BAM engines
ARX=150bhp ....4x4, golf Gti etc
AUQ=180bhp .....TT, vrs, cupra, golf anni's etc
BAM=225bhp....Cupra R, TT maybe others(not sure)
iirc there a210 bhp engine as well ...maybe
This is too my limited knowledge:O. If wants to correct me ......carry on
Link to comment
Share on other sites
the 4x4 will never ge the same wheel power as a vrs as even when the 4x4 is decoupled its always running the transfer box/prop/inlet side of the rear diff so it always has higher losses :)
the engines have the same short blocks and the heads are the same apparently and they run the same turbo and manifold, infact my turbo came from a vRS when mine broke.
Link to comment
240 is possible from an AUQ engine which is what the OP has. Just needs the same mods you did to your ARX engine plus a good custom remap.
So are we saying 250ps is safe for an unmodified AUQ engine block?
Sorry to ask again but is this generally accepted as safe?
Edited by G-slave
Link to comment
I'd say that power level is safe for the internals but then you won't get that power level unless you use a bigger turbo, you are really pushing the boundaries of the standard turbo at 240bhp and that will be having spent a fortune on mods like a turbo back exhaust, sports cat, TIP, front mount intercooler etc... and if you are going to put a bigger turbo on then changing the internals would be definately be necessary otherwise you start winding up the boost and the engine will go bang :eek::thumbdwn:
Or is it a 50bhp shot of laughing gas you are considering? :confused:
Edited by chicken_eyebrow
Link to comment
Yeah, makes sense;
240BHP is considered safe (but almost not achievable with standard turbo; the K03s)
and if you change the Turbo and up the pressure then you need to make sure the boost does not exceed a certain limit deemed safe for the internals.
That boost limit would roughly equate to 300bhp, but it is incorrect to say boost=bhp as it will all depend on the map and health of existing components
So what I have just learned is that this safe limit I keep wondering about, is actually in direct relation with the boost pressure.
dare I ask; what is acceptable boost pressure for KO3s, running on AUQ with aftermarket TIP, the hose between the Turbo and IC and a panelfilter? (no laughing gas, thanks)
Edited by G-slave
Link to comment
  • 8 years later...
My AUQ 1.8T Octy made 259bhp and 280ib/ft with 23psi boost.  You also have to get yourself a good mapper who will take his time.  Chris @ CC Tuning in my case, the best.
Edited by sammyhale30
Link to comment
  • 2 years later...
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
