Rear Windscreen Washer Issue
Recommended Posts
Anyone had this issue?
I knew it wasn't working, so I invesigated the issue earlier to find it sprays out by the CD changer. Obviously a broken pipe, just wondered if it was a common problem.
Luke
Link to comment
Share on other sites
Luke
A common problem is that the plastic tubing falls off the junction sections between
pipe lengths. Not heard of the pipe itself failing, it's fairly robust tubing.
Link to comment
there is a joint in the pipework in the wiring loom underneath the changer. Just reconnect the pipes and your good to go. Some people suggest using a tie-wrap to prevent it from happening again, but I would rather an easy to access joint popped rather than one somewhere else in the event of a blockage/frozen jet/etc.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
