Battery tray question
C.D-vRS
After seeing some Fabia vRS's on here with battery covers I was under the assumption that mine had gone missing at some point so I bought this: http://cgi.ebay.co.uk/SKODA-FABIA-VRS-BATTERY-BOX-BREAKING-SPARES-/320585953408?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4aa4697080
However it does not fit. Are there 2 different types then?
Here's mine:
Other ones I've seen:
Thanks.
Edited by cd2010
I would have thought it would be cheaper from a main dealer ,you only want the top. Maybe it is a wrong replacement battery <too large dimensions> so previous owner removed it.It is hardly something to go missing on its own :thumbup:
I got the lid only, for £10
facelift vrs's 54 plate onwards have no battery cover as it was got rid of during the facelift
Incorrect - my facelift 2004vRS had a cover - though I admit my facelift car fifn't have the changed dashtop - the changes weren't all introduced at the same time. I thought the change might have been when the BLT engine was fitted in late 2005? I think the covered versions look much better and potentially the uncovered ones will be vulnerable to moisture. However the cover can't be retrofitted (edit - according to the dealer when I mentioned it when I bought the car).
Another change is in the engine cover - my 2004vRS had a nice coloured Skoda badge - the 2007vRS has a plain black one...
Edited by DRJ
Guest BigJase88
sorry mr holmes
well 2004/2005 is when it changed....
the newer motors don't have the battery cover!
and i have an ASZ 05 plate with NO cover so it isn't a BLT engine 'thing' either
Oh and retro fitted also 8)
no such thing as 'cant'
"Can't" without also changing other components - anything can be done if you really try - but it CAN'T simply be clipped into place since the receiving clips aren't there hence CAN'T be retrofitted TO THE EXISTING BATTERY HOLDER !
Guest BigJase88
well mines is SJ05 GWN
NO cover :)
its just a crossover between PFL and FL
some car's will be built earlier than others and registered later, pot luck really
Edited by BigJase88
All's well that ends well. However I do think mine looks vulnerable so I might have to do something having participated in this thread...
Edited by DRJ
