TTS short shifter
Guest
Recommended Posts
Can some one confirm then which is the correct one for my 08reg vrs petrol 6 speed please and if anyone knows part number and from where so I can get 1 ordered please ?
Link to comment
Share on other sites
Hi guys. Does anybody know any short shifter that fits Skoda Octavia 2 1.9 tdi 5 speed, bxe engine and jcr gearbox ?
Your's should be the 8J0711046D  or the 8J0711051D.  I think you'll find your gearbox is from the MQ250 series.
Link to comment
It'll be quicker to drive to Germany.
I ordered mine on a Thursday but there was no stock in the UK so had to be shipped from Germany. Arrived Monday, fitted Tuesday.
Was it the same part number I mentioned?
Any pics , feedback on de dif. would be nice
Link to comment
Anyone please so can get 1 ordered
Link to comment
Mine had an E as the final letter (8J0-711-046-E).
The movement is quite a bit less, feels positive. Not a lot to say really, worth the 30 squids and a couple of hours work.
Edited by Wayne Kerr
Link to comment
Just wanted to say thanks to everyone on this thread, having read through it all and watched the vid all my questions were answered without even needing to post!
Fitted today, quite a noticeable improvement, always thought the shift was a little long, this has made it far better! As a lot of people have said, hardest part was getting the air box/filter on and off!
Cheers all
Rusty
Link to comment
Hi lads
can you tell me the part number for this part as a few a floating around now
the car is a 2008 VRS Tdi
https://www.google.co.uk/search?q=8J0711046E&safe=off&es_sm=122&source=lnms&tbm=isch&sa=X&ei=1p8eVbTiJZb1armngfAJ&ved=0CAgQ_AUoAg&biw=1920&bih=989
is this it exactly?
This might help also
Link to comment
MQ350 gearbox on the VRS mk2 PD170 and gear linkage fitted today
8J0 711 046 E was the newer part number
Not really a short shifter as this was discussed on many VW and Audi forums but but reduces throw about 13mm in total
Brought the gearknob head 5mm in closer from the dash end and 8mm from the opposite handbrake end
It is definitely an improvement with nice, slightly quicker shifts that seem better suited to the hand use not the whole arm being used
£32 from TPS and very easy to fit
The hardest part was fishing the 13mm socket out that fell onto the undertray  :p
  • Like 1
Link to comment
  • 4 weeks later...
Hi The short shift can be bought off e bay for about £35, less than half price of Forge and fits the same (MK2 2 2010 Vrs) recommended mod only shortens shift not side to side
is this short shifter ok for the MQ350 6 speed gearbox?
post a link up buddy
Link to comment
I take it you have to remove the air box inlet (2 torx screws) from the from the front bulkhead and the air box (1 torx screw) as well? If I got a garage to do this job...15 mins max what should I be paying? Unfortunately I don't know any friendly garages nearby or any mates who are mechanically minded!!!
K:)
Link to comment
K:)
its very easy, is your a petrol or diesel?
the TDI has just a few little bits to undo and very easy
Link to comment
its a diesel, just concerned about taking the air box bit out.....the vid on page five here shows it on a golf and it looks so simple but then when I lifted the bonnet and saw mine was so different it didn't look so easy to me!!!.....I'm hopeless at mechanicals!!!!
K:)
Link to comment
Yours is dufferent to the airbox in the video. I had mine out for the first time at the weekend to check and bleed the slave cylinder. Its just one 5mm allen bolt and pushed onto two rubber lugs then unclip the air intake pipe going to the box. Its a 5 minute job.
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
