O2 sensors
Recommended Posts
Does anyone know how many O2 sensors the Octy has and what the part numbers are?
Also, has anyone ever attempted to replace them? Mine need doing (and have done for a long time) but I've been told it can be a nightmare job, as sometimes part of the old ones can snap of when you try to remove them.
Thanks as always ;)
Link to comment
Share on other sites
You will have two sensors, the front one being a 5 wire wideband sensor, and the back one a normal 4 wire.
They are both easy enough to get to (under the car). As long as the threads don't pick up, and you don't go mad with them, you shouldn't have too much to worry about.
When I fitted my decat, mine came out easy.
Can;t help you with part numbers though
  • Like 1
Link to comment
That'll do it. As long as you have the right fit and a bit of leverage to crack the first bit and loosen it they'll unscrew by hand.
Link to comment
Excellent - cheers guys.
I'm guessing it's one of those situations where only genuine will do? Seems a tad pricey: http://www.skodaparts.com/product/octavia-lambda-oxygen-sensor-front-1996-2009-30493
Can only find the front one though - second one is evading me :P
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
