Artdeshine artdekotsos
Dinski
Recommended Posts
Did the full works on the car today, snowfoamed the full works, won't bore you with routine....
Products used were
Snowfoam valet pro ph neutral
Megs gold class shampoo
Farecla clay mit
Marks new lush drying towel
Blue moon as a drying aid
And my lsp artdekotsos, and what a joy to apply this wax is, I can't pick between this and the abyss now.
I used a red foam application pad and it went on a dream, I did learn fast you have to remove this stuff pretty quick otherwise it drys chalky and can be a **** to remove.
The finish it leaves is second to none absolutely silky smooth high gloss. Amazing!
I then used NGPS over the top just to add a bit more shine, both products work so well together, I would recommend to anyone.
  • Like 1
Link to comment
Share on other sites
Looks great Carl
Nice to see you out there doing it as well :thumbup: :beer:
Thanks Chris, it's been a long time tbh.
Was really good to get back into it, I also used FK Orange sparkle on the alloys, it's really soft on the alloys no chemicals, it doesn't eat through like purple rain but with a little agitation it does a good job.
I was going to use clarity from mark on the alloys but I was totally tired out afterwards so I may apply it tomorrow.
I used revival Matt look tyre dressing on the tyres from mainze car care, also a great product!
Link to comment
Very nice looking motor super clean [emoji106]
Thanks mate, not had chance to spend that kind of time on the car for a while and it was s joy!
  • Like 2
Link to comment
I was supposed to be giving up waxes!
I do think this is one that everyone should own, or at the very least try! In which case you would probably buy it anyway.
I got the big tub but the small one is very cheap for such a quality wax and will probably last longer than most will own their car.
  • Like 1
Link to comment
Not so much that, as he said he only dipped in the pot 4 times for the whole car but used NGPS every section he did.
Sounds more like he will have 90% NGPS on the car and 10% wax.
I applied very thin, without the need of a qd and it worked wonders!
Each to their own I guess.
  • Like 1
Link to comment
I havent got any Carl
But if I did, I wouldnt use the DA with wax
Some Detailers do, but I find applying by hand suits me best
I wouldn't normally but it's such a buttery wet wax, I thought it would work quite well.
Link to comment
If it saves you time and the wax is soft enough, then fine
If you bring it over we can try it on your Wife's Yeti
Yeah that sounds good
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
