Rob's Ur Quattro
RobClubley
Driving Rusty reminded me about the rather annoying rev cut about 4000rpm and I decided to have a quick look at it using this guide.
http://www.intendedacceleration.com/tip_2.html
Well the idle switch works, and the air intake temp sensor, but the metal leaf on the full load switch was bent meaning it would never switch, and I'm missing the throttle adjuster clip (my mistake I'm sure) which means I can't actually apply full throttle.
The full load switch isn't connected to the ECU so that's not the issue, everything else seems to check out.
Next step, more tests:
https://audifans.com/mirror/www.isham-research.co.uk/quattro/wiring/Typ85/mac01pin.html
I've also jacked up the car and put it on stands to test out the ABS more fully. Watch this space!
120287470_2856993604400917_6235788459289
Clips on the way from Classic Quattros.
Tested the resistance of the ABS sensors - fronts 1050 and 1058, rears 1117, 1122. So pretty close.
Spinning the wheels changes readings very slightly.
With ignition on I'm getting 11.2v to the switched live on the ABS, which could be a part of the issue. Not sure why but slightly low voltage seems to be common around the car even though the battery is good.
I removed and re-seated the 4 sensors again. Wasn't sure the front left was in properly so I put the car back on the ground and went for a test drive. AS soon as I get over 30kph the ABS disables.
120832807_2872064449560499_7798809306130
Rob, as skomaz said check your earths.
In view of the other "modifications", the the previous owner has been up to with the improvements, has he been monkeying around with the dash earth?.
When you reseated the sensors, did you put them in dry, or did you use any lubrication?. I normally put a light coating of silcone grease round them to make sure they slide in and seat properly.
Voltage drop could also be down to oxide buid up on really old wiring, What is the line resistance like on the wiring you are testing Rob?.
Good luck,
Phil.
I was in Ohakune this weekend so popped over to Smash Palace for a little pick over the Coupes they have there. Got a nice condition dash surround and some spare switches.
I went there about 3 years ago and pulled quite a few parts off the white Coupe Quattro but didn't have enough cash for everything. They put a pair of Frankani tail lights aside for me and I planned to collect them soon after. When I called back they couldn't find the lights, they were somewhere upstairs, which as you can see from the photos is a rather packed Aladdin's cave of car parts. I called a year or so later and had a look myself, no luck, so I assumed they had been sold to someone. This time I thought I'd have one more look, and after 15 minutes going over every shelf with my phone torch, right at the end I spotted them on the floor!
Absolute score, and they're better than the ones I have, except for a hairline crack on the side of one. But I am very pleased!
121672499_2903941249706152_3480493172056
122028741_2903941766372767_7725699223803
121628672_2903942013039409_1584837820910
122034511_2903954276371516_7128849555344
121829945_2903954233038187_2593702907585
122051801_2903954466371497_2817750420120
122035598_2903954553038155_1962282420487
122044817_2903954636371480_2111048051417
122101365_2903954723038138_2207028005245
  • Like 3
Ahhhh, f$%k it. Re-seating the sensors again and for the first time I noticed this. Damaged rear speed sensor.
Of course these things are rarer than rocking horse poo and the one I've found on Ebay is extortionately priced.
Also it looks like there's at least one tooth missing from the hub at that side.
122458387_2911283965638547_2996960856340
122437561_2911284235638520_4039828601757
122445470_2911284585638485_5007442430847
122439984_2911284762305134_2224008256010
I re-checked the intake air temp sensor - wiring is good to the computer and showing 22 ohms across the terminals.
I also replaced the dodgy looking terminals to the throttle switch and checked continuity and operation of both switches.
123138163_2943033715796905_8224252700792
Then I found this
http://www.audiurquattro.de/ecu/check.htm
To check the speed sensor, remove the plug from the ecu and connect an LED across terminals 11 and 24.Crank the engine over with the starter.
If the Led flickers on cranking the sensor AND wiring are good.
All good
Checking the reference sensor is similar. Connect the LED across
terminals 12 and 13 of the ecu connector. Crank the engine over, the led should flicker. If it doesn't, check the wiring.
This one didn't flicker.
Once I pulled it out it appeared the wiring was damaged on the sensor. So maybe this is the source of the problem.
123205116_2943034069130203_5433662347100
123139272_2943033965796880_5078812243835
123367363_2943034305796846_7397659584231
I went back to re-check and the sensor that I pulled out with wiring repairs is the one that tests as working with the LED method. That's the speed sensor.
The other sensor lower down is the TDC sensor. Wiring continuity is good to the connector from the ECU plug, and the engine won't fire with TDC sensor disconnected, so it is doing something, but it fails the LED test.
Damn that was close!
123653584_2950644815035795_1908722640527
123879473_2952988648134745_7585701551780
Gauges for diagnostic purposes...
124417416_2963611340405809_7928330878550
Professional install bro.
The good news is oil pressure is good.
Patrizia still warns about oil pressure even when disconnected from the pressure switch. The switch opens when engine has pressure, so if Patrizia was warning based only on this switch she should have shut up with it disconnected.
Need a co pilot to check boost levels safely.
125076578_2966104093489867_8520899667137
124567717_2966104193489857_3980378293799
Edited by RobClubley
I found a wiring diagram for 84 Patrizia which agrees with what I have and my loom, and only has the one low pressure sensor.
124443964_2968800363220240_9625483800672
Bit of progress. At 4000ish RPM I'm hitting 12PSI of boost. Factor manual says max boost should be no more than 10.2PSI. So maybe I have the wrong wastegate spring. Or wastegate isn't working correctly.
125070932_2971672496266360_5566517331247
Just noticed the Honda Beat and Suzuki Cappucino in the pics - always liked those but they look even smaller these days given everything has grown over the years!
I love the look of these tyre valves, but this one decided it would only let air out when the cover stuck in place.
Bugger that, changed back to a standard valve 🙂
Thanks to Jason at The Tyre Clinic Porirua for sorting it and not charging for the privilege.
125210083_2981314521968824_1804063727233
125227411_2984085408358402_7051094822208
Just over 200 miles covered since the WoF. I think I've fixed the Check Oil Level warning, and as far as I can tell it was just poor contacts on the relay as since the last time I pulled the relay out and put it back a couple of times doing diagnostics, the oil light is off and the warning has stopped during driving. Now she natters about checking brake pads (the wires from the pads don't have anywhere to plug into) and occasionally tells me brake lights not working (they are) and please refuel. Talking of fuel I recon I've averaged about 14.5l/100km, but lots of school runs and stuff.
My speedo and a few other bits stopped working the other day. After a bit of mucking about I traced it to a broken earth wire on the relay that activates my little switched life fuse box that powers a few bits and bobs. Including the speedo sender.
I had a hissing in the footwell after a drive up to drop the ozone generator off. The pipe the ECU uses to measure boost had split at the end and fallen off.
Then finally I did the school run yesterday and turned the key to go home.. nothing, totally dead. I traced that to a failure of my own - when fixing the boost pipe issue I'd pushed a wire out of the way a little, just enough for it to catch on the steering column, wrap around and snap the wire. The one that leads to the starter relay.
Kneeling on the ground in the rain and wind rigging a temporary fix to get home was not much fun!!
I've done some better cable management and cable-tying now.
  • Like 2
3 hours ago, Lady Elanore said:
Do you ever wonder if you should have replaced the entire wiring loom and similar :D  or at least have done it in one go instead of bit by bit as you are now :rofl:
I don't wonder I know!
If I started again I'd have the engine out, loom out, rewire and fix. But that seemed like a step too far at first as it appeared to be a relatively working car.
  • Haha 1
  • Sad 1
