Rob's Ur Quattro
RobClubley
Recommended Posts
20 hours ago, Lady Elanore said:
I agree with Ken, Rally cars shouldn't look slammed or too low (the exception being the Lancia Stratos which can look any way it wants as it it utterly gorgeous :D )
Cheers quine. There are exceptions though, notably the Lancia 037 (Rally) and Opel Manta 400, which I associate both of more with tarmac rallying than with gravel.
Link to comment
Share on other sites
The pad must be out of place. It still seems to be the same after a drive but isn't binding now. Will take it off again and check/re-grease the pins.
Started following this guide http://audifans.com/mirror/www.isham-research.co.uk/quattro/wiring/Typ85/mac01pin.html
to diagnose the rev limit at 4500rpm. The inlet air temp sensor wasn't so good! It has been fixed before by someone even worse at soldering than me. I melted the solder off and switched to crimps as suggested in the guide. The car definitely feels a bit better and I accelerated up to 6500 in second. I wasn't in a suitable place to go any faster!
46312964_1568861256547498_34897670136922
46348683_1568861296547494_44265796109389
46445958_1568861269880830_27450504021719
46349055_1568861329880824_42097974073255
  • Like 1
Link to comment
Installed at last! I spent ages trying to get the pressure accumulator out using an oil filter wrench and breaker bar but couldn't get a grip. So I asked the internet nicely via Neighbourly and a total stranger lent me his big grips for 15 minutes. Job done! Also it took ages yesterday to locate a turkey baster to drain the fluid before installing.
46469231_1569983933101897_35429866449466
46375033_1569983903101900_24564512171784
46366291_1569984013101889_72704534567903
46373888_1569984033101887_60722915197614
46457871_1569983886435235_31896539190263
Edited by RobClubley
  • Haha 4
Link to comment
15 hours ago, RobClubley said:
I've changed the blades, but why change the arms? Not sure if they're available.
Arms, because that's the only way to change the springs, and I think you may have a problem with low blade to screen pressure.
Link to comment
The springs seem okay but that's a good thought, will see what's available. Need to look at the motor too as it seems a bit sluggish, particularly in its fastest speed.
Link to comment
I don't know about this either, but there's a good chance the motor just needs new brushes rather than completely replaced.
Link to comment
Disconnect the motor from the linkage first Rob to check the linkage is free, it could be partially siezed with filler dust from it's body shop stay.
As Ken said, wiper brushes are a cheap fix for the motor, unless the comm has got hot.
  • Like 1
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
