Upgraded clutch
:rofl: - avoid looking at my posts within the JBS forum section then :D
I'm kinda starting to scare myself on how much I'm spending, but I want a reliable car in addition to getting a bunch of extra power, and I'm only doing this the once.
All good fun :D
Be carefull what clutch spec you go for, a friend has "lost faith" in his Sachs clutch (organic) at 290lb/ft and only 1500 miles. May be a duff one but Sachs are not prepared to enter into warranty negotiations.
Others have had good results with different plates.
Can't fault JBS 400 lb/ft Kevlar clutch - It will take some serious clucth dumping abuse and hasn't faltered once for me. :cool: Cost me £600 all in. My engine & box were apart anyway, so it was only a matter of "shoving it back in" once I got it back through the post. :D
Admittedly you're talking about a car being off the road for a week or more whilst the DMF is machined down, but in my case it was very much worth it. ;)
Be carefull what clutch spec you go for' date=' a friend has "lost faith" in his Sachs clutch (organic) at 290lb/ft and only 1500 miles. May be a duff one but Sachs are not prepared to enter into warranty negotiations.
Others have had good results with different plates.[/quote']
I fully agree.
But the petrol ones do not seem to be as good as the diesel ones.
I would reccoment this clutch to my mother it is that good.
The Kevlar one as quoted does seem to be better on the diesels too.
We have also been doing some testing on a 540lb/ft clutch for the petrols too.
Sarah
Another doubter for sachs clutch, supposed to be rated to 318 lb/ft yet was slipping on a petrol producing a peak of 310 lb/ft, Flywheel was in perfect condition before fitting and all bedding in procedures were adhered to ~ and more.
This was on a Seat, but also on vwvortex there are a few haters
http://forums.vwvortex.com/zerothread?id=2332756
Another doubter for sachs clutch' date=' supposed to be rated to 318 lb/ft yet was slipping on a petrol producing a peak of 310 lb/ft, Flywheel was in perfect condition before fitting and all bedding in procedures were adhered to ~ and more.
[url']http://forums.vwvortex.com/zerothread?id=2332756[/url]
Most of the pertol ones have now been taken off the market.
It was something to do with the pressure plate.
If I was you I would get in touch with Sachs and see if they will do anything for you.
They do know that there is an issue.
sarah
I fully agree.
Sarah
Sarah,
Just a couple of questions:-
The Sachs clutch is £711 fitted, how much is the JBS Kevlar clutch fitted?
I believe the flywheel has to be in perfect condition for the Kevlar clutch to be fitted. Is the same with the Sachs one?
Thanks,
Jon
Hello Des
Be carefull as what has been said on here there are differnt specifications.
Sarah
Just clarifing John's post as you can see and yes there certainly are differant specs, trust me I know. :)
