Technical Data
the_ape
Recommended Posts
Hi all, does anyone have the following (for a test of some software....)
Displacement, bhp and torque and what RPM's, Compresion Ratio, Max RPM, the ratios and final ratio of the gears, car weight, weight balance % front to rear, wheelbase, drag coefficient, height, width.
For the Furby and Octy vRS.
Oh found this review as well http://www.carkeys.co.uk/launch/LA000217.htm Duno whether it's been posted before ;)
Link to comment
Share on other sites
ive just read that review, and i totally disagree with it!!!
Why Sign It Off?
So . . . on the one hand the vRS rides like a cement mixer, and on the other it handles like a cross-channel ferry. This is the worst possible compromise, and it leads me to wonder who exactly drove the last of the prototypes and said, "yes, this is fine, don't touch a thing."
It wouldn't take long to fix it. Higher-profile tyres, stiffer springs, better damping, perhaps a further reduction in ride height - this is not rocket science, and with appropriate tweaking it could all transform the vRS into an absolutely superb hot hatch. A revised version brought on to the market as soon as possible would be more welcome than I can say.
On a slightly different note, several of my fellow scribblers on the launch expressed the view that the vRS has a very ordinary interior for a car which costs around
Link to comment
Oh.. and to answer your question.. this is what i found:
from Skodasnewtoy
Item
Value
Acceleration 0 - 100 km/hr
9.6
Airdrag coefficient
0.33 Cw
Brake - front: disc brakes, with single/piston floating caliper
288 mm
Brake rear: disc brakes
239 x9 mm
Braking system: hydraulic dual circuit brake system with diagonal interconnection, vacuum assisted
Ground clearance
142 mm
Clutch: hydraulic single dry clutch disc with membrane spring, asbestos free
CO2 emissions (combined):
EU3: 138 g/km
Comfort dimensions - front (max/min)
1100/860 mm
Comfort dimensions - rear (max/min)
846/606 mm
Compression ratio
19.0:1
Fuel consumption - combined
EU3: 5.1 l/100km
Fuel consumption - extra-urban
EU3: 4.2 l/100km
Fuel consumption - urban
EU3: 6.7 l/100km
Degree of comfort
1,871
Engine displacement
1,896 cm3
Elasticity 60-100 kph 5/6
11.5/18.7 seconds
Elasticity 80-120 kph 5/6
10.6/14.8 seconds
Engine type: Four-cylinder, turbo-charged diesel engine, turbocharger with self-aligning VTG blades, in-line, liquid cooling system, high-pressure direct injection system - pump nozzle, OHC, transverse in front
Front axle: McPherson strut with wishbone arms and torsion stabiliser
Front overhang
869 mm
Front overhang angle
16
Front wheel drive
Fuel injection system: electronically controlled high-pressure direct injection system - pump nozzle
Height (kerb weight)
1,441 mm
Kerb weight
1,245-1,315 kg
Length
4,002 mm
Max. engine performance/revs
130 bhp /4,000 rpm
Max. torque/revs
310 Nm/ 1,900 rpm
Payload
475-405 kg
Permissible roof load
75 mm
Rear axle: compound-link crank-axle
Rear overhang
671 mm
Rear overhang angle
17
Seating capacity
5
Steering system: direct rack and pinion steering with electro-hydraulic power steering
Storage capacity
260 litres
Storage capacity with rear seats folded down
1,016 litres
Stroke/cylinder bore
79.5/95.5
Tank capacity
45 litres
Top speed
126 mph
Total weight
1,720 kg
Track front
1,432 mm
Track rear
1,422 mm
Transmission gear ratios
I-3.769,II-2.087,III-1.324, IV-0.911,
V-0.902,VI-0.756,
R-4.549.
Final drive: I-2.955;
II
Link to comment
Doh, missed that.......
Anyhow here's the results......
FABIA VRS
CAR SPECIFICATIONS
Engine Displacement: 1986 cc.
Engine Location: FRONT
Engine Type: TURBO
Engine Max Horsepower: 130 bhp
@: 4000 rpm
Engine Torque: 230 lb-ft
@: 1900 rpm
Compression Ratio: 19.0 :1
Maximum engine speed: 4500 rpm
Start Engine Speed: 1800 rpm
with Clutch: DUMP
Transmission Type: MANUAL
Number of Gears: 6
Gear Ratio 1st: 3.77 :1
Gear Ratio 2nd: 2.09 :1
Gear Ratio 3rd: 1.32 :1
Gear Ratio 4th: 0.91 :1
Gear Ratio 5th: 0.90 :1
Gear Ratio 6th: 0.76 :1
Final drive ratio: 2.96 :1
Driving wheels: FRONT
Car test weight: 2744 lb.
% weight on front wheels: 60 %
Wheelbase: 96.9 in.
Tire section width: 205 mm.
Tire circumference: ft.
Wheel diameter: 16 in.
Tire profile: 45 %
Coefficient of drag: 0.33
Frontal area: sq.ft.
Overall height: 57.0 in.
Overall width: 64.8 in.
Ground clearance: 5.6 in.
FABIA VRS
GENERAL PARAMETERS
Air Temperature: 65 deg. F.
Barometric Pressure: 29.38 in. Hg.
Relative Humidity: 55 %
Elevation above Reference: 0 ft.
Headwind (+), Tailwind (-): 0 mph
Road Grade (+=Ascend, -=Descend): 0 %
Shift Time, Manual: 0.50 sec.
Shift Time, Auto: 0.30 sec.
Engage Time, Manual: 0.20 sec.
Engage Time, Auto: 0.10 sec.
Clutch Slip Max. Time, Manual: 5.00 sec.
Brake Release Time at Start, Auto: 0.10 sec.
Trans. Engage Method-Lin,Prog,Regr: R
Shift@O=Optim,R=Redline,D=Driver,P=Prog: O
Engine Free Decel Rate: 2000 rpm/sec
Engine Bog Down Decel Rate: 4000 rpm/sec
Engine Wheelspin Decel Rate, Manual: 500 rpm/sec
Engine Clutch Slip Decel Rate, Man.: 250 rpm/sec
Engine Trans. Slip Accel Rate, Auto: 750 rpm/sec
Engine Wheelspin Accel Rate, Auto: 250 rpm/sec
Max. Coefficient of Static Friction: 1.00
Max. Coefficient of Kinetic Friction: 0.85
Coefficient of Rolling Resistance: 0.013
Tire Expansion Factor: 0.020 %/mph
Hot Tire Pressure: 35 p.s.i.
Tire Tread to Section Width Ratio: 90.0 %
Wheel and Tire Weight: 45 lb.
Minimum Engine Speed: 700 rpm
Zero h.p. Engine Speed: 600 rpm
Turbo Start Speed: 3000 rpm
Max. Torque Conv. Slack Until, Auto: 2000 rpm
Low Max. Brake Torque Speed, Auto: 2000 rpm
Time Increment: 0.05 sec.
Start Time after Car Moves: 1.00 ft.
Mechanical Losses-Auxiliaries: 2.00 %
Mechanical Losses-Manual Trans.: 6.00 %
Mechanical Losses-Auto Trans.: 8.00 %
Mechanical Losses-Differential: 4.00 %
Mechanical Losses-Axles & Shafts: 5.00 %
Mechanical Losses-Torque Converter: 3.00 %
Max. Clutch Slip Losses, Manual: 10.00 %
Max. Trans. Slip Losses, Auto: 15.00 %
Max. Torq. Conv. Torque Multiplier: 2.25
Effective Engine Radius: 3.0 in.
Drive Shaft Radius: 1.0 in.
Center of Gravity from bottom: 30.0 %
Graphics Aspect Ratio (EGA): 0.75
Graphics Aspect Ratio (VGA): 1.00
Sound Effects (Y=Yes, N=No): Y
FABIA VRS
STANDING START ACCELERATION RESULTS
Starting vehicle speed: 0 mph
Starting engine speed: 1800 rpm
Starting gear: 1st
Optimum Shift Points:
1st 4480 rpm @ 28 mph
2nd 4330 rpm @ 49 mph
3rd 4170 rpm @ 75 mph
4th 3510 rpm @ 92 mph
5th 3810 rpm @ 101 mph
Time to Speed:
0- 30 mph............ 3.0 sec.
0- 40 mph............ 4.2 sec.
0- 50 mph............ 6.6 sec.
0- 60 mph............ 8.7 sec.
0- 70 mph............ 11.4 sec.
0- 80 mph............ 15.7 sec.
0- 90 mph............ 20.2 sec.
0-100 mph............ 27.6 sec.
Time to Distance:
0- 100 ft............ 3.3 sec.
0- 500 ft............ 8.9 sec.
0-1320 ft.(1/4 mile). 16.6 sec.
@ 82.4 mph
Top Speed............. 120.5 mph
Link to comment
And here we have a Re-Mapped version ;)
FABIA VRS REMAP
CAR SPECIFICATIONS
Engine Type: TURBO
Engine Max Horsepower: 185 bhp
@: 4000 rpm
Engine Torque: 320 lb-ft
@: 1900 rpm
with Clutch: DUMP
Number of Gears: 6
Wheelbase: 96.9 in.
Tire profile: 45 %
FABIA VRS REMAP
GENERAL PARAMETERS
FABIA VRS REMAP
Starting gear: 1st
1st 4500 rpm @ 28 mph
2nd 4420 rpm @ 50 mph
3rd 4220 rpm @ 76 mph
4th 3620 rpm @ 95 mph
5th 3920 rpm @ 104 mph
Time to Speed:
0- 30 mph............ 2.5 sec.
0- 40 mph............ 3.6 sec.
0- 50 mph............ 4.7 sec.
0- 60 mph............ 6.8 sec.
0- 70 mph............ 8.6 sec.
0- 80 mph............ 11.5 sec.
0- 90 mph............ 14.3 sec.
0-100 mph............ 18.5 sec.
Time to Distance:
0- 100 ft............ 3.2 sec.
0- 500 ft............ 8.3 sec.
0-1320 ft.(1/4 mile). 15.2 sec.
@ 92.9 mph
Top Speed............. 134.0 mph
Link to comment
And if we could make it up to 200Bhp / 400ftlb :D
FABIA VRS REMAP
CAR SPECIFICATIONS
Engine Type: TURBO
Engine Max Horsepower: 200 bhp
@: 4000 rpm
Engine Torque: 400 lb-ft
@: 1900 rpm
with Clutch: DUMP
Number of Gears: 6
Wheelbase: 96.9 in.
Tire profile: 45 %
FABIA VRS REMAP
GENERAL PARAMETERS
FABIA VRS REMAP
Starting gear: 1st
1st 4170 rpm @ 26 mph
2nd 3890 rpm @ 44 mph
3rd 3670 rpm @ 66 mph
4th 3020 rpm @ 79 mph
5th 3290 rpm @ 87 mph
Time to Speed:
0- 40 mph............ 3.5 sec.
0- 50 mph............ 5.2 sec.
0- 60 mph............ 6.5 sec.
0- 70 mph............ 8.7 sec.
0- 80 mph............ 11.3 sec.
0- 90 mph............ 14.5 sec.
0-100 mph............ 17.5 sec.
Time to Distance:
0- 500 ft............ 8.2 sec.
0-1320 ft.(1/4 mile). 15.1 sec.
@ 92.4 mph
Top Speed............. 135.0 mph
Link to comment
WTF are they on! everyone else has commented how much better it is than the Ibiza variant on ride quality handling, and because the car looks the part, inside and out! - even ibiza owners!
i will agree that it could do with being a bit lower.. but the handling of it is fine for that power. its comfortable and sporty!.
Leave Carkeys alone.
Terrible ill-informed Octavia vRS review as well.
The vRS is screaming out for four-wheel drive, and since that's going to be available on the forthcoming vRS estate, it may also turn up in the hatchback.
Link to comment
I thought the displacement was 1896cc, and not 1986cc (i.e 2 litre...) - I hope this doesn't affect the outcome, as I'm also worried I didn't see any reference to "diesel" in the engine type, only "TURBO" - which could be petrol... :D
Anyway - very good figures either way - I just hope that's exactly what they'll do in reality. :thumbup:
Link to comment
Octavia RS
Displacement = 1781
BHP = 180 @
Torque = 172 @
Compression Ratio =
Max RPM = 7000
Ratios:
1st = 3.3
2nd = 1.94
3rd = 1.31
4th = 1.03
5th = 0.84
Weight = 1260
F/R % =
Wheelbase = 2512
Drag = 0.28
Width =
Height =
Got the other bits at home, anyone want to try and fill the blanks?
Link to comment
From the fact sheet at http://www.skoda-auto.com/showroom/octavia/download/ :-
Hatch:-
Overall width 1985mm (1731mm excluding door mirrors)
Overall length 4507mm
Wheelbase 2512 (fwd) 2520 (4x4)
Track 1513 (fwd) 1516 (4x4)
That's for the standard model(s) - I guess the vRS will be a bit lower.
I haven't been able to locate a definitive figure for the compression ratio - the fact sheet on Skoda Auto's site doesn't give it - but other sources suggest it's either 9.3 or 9.5 to 1
Link to comment
I've adjusted the displacement figure, Sorry typo, makes very little difference, (slight difference to the torque/power curve of the car), but the times are no difference.
Will do the Octy......
Link to comment
Anyone know what final ratio is?
Found a bit of software on one of my old laptops that calculates this sorta stuff, used to use it for my MR2 to work out what sorta mods were worth doing, PM me if you want a copy and I'll mail it ya (600k or so so cant upload it)
cheers
edit : not too worry got it http://www.supercarsite.net/octavia_rs.htm
Link to comment
Does this look close to real?
SKODA OCTAVIA VRS
CAR SPECIFICATIONS
Engine Displacement: 1781 cc.
Engine Type: TURBO
Engine Max Horsepower: 180 bhp
@: 5500 rpm
Engine Torque: 173 lb-ft
@: 1950 rpm
Compression Ratio: 9.5 :1
Maximum engine speed: 7000 rpm
Start Engine Speed: 5900 rpm
with Clutch: DUMP
Number of Gears: 5
Gear Ratio 1st: 3.30 :1
Gear Ratio 2nd: 1.94 :1
Gear Ratio 3rd: 1.31 :1
Gear Ratio 4th: 1.03 :1
Gear Ratio 5th: 0.84 :1
Gear Ratio 6th: :1
Final drive ratio: 3.06 :1
Car test weight: 2985 lb.
Wheelbase: 98.7 in.
Tire profile: 55 %
Coefficient of drag: 0.28
Overall height: 55.6 in.
Overall width: 68.1 in.
Ground clearance: 5.0 in.
SKODA OCTAVIA VRS
GENERAL PARAMETERS
SKODA OCTAVIA VRS
Starting engine speed: 5900 rpm
Starting gear: 1st
1st 6880 rpm @ 51 mph
2nd 6540 rpm @ 83 mph
3rd 6240 rpm @ 118 mph
4th 6160 rpm @ 149 mph
Time to Speed:
0- 30 mph............ 2.7 sec.
0- 40 mph............ 3.8 sec.
0- 50 mph............ 5.1 sec.
0- 60 mph............ 7.7 sec.
0- 70 mph............ 9.6 sec.
0- 80 mph............ 12.0 sec.
0- 90 mph............ 16.1 sec.
0-100 mph............ 19.9 sec.
Time to Distance:
0- 100 ft............ 3.4 sec.
0- 500 ft............ 8.6 sec.
0-1320 ft.(1/4 mile). 15.7 sec.
@ 89.0 mph
Top Speed............. 141.6 mph
15.7sec Qtr Mile aint too bad for a standard car!.... Working on a Jabbad version...... Gimme 5 ;)
Link to comment
Here we go, the Jabba'd version.....
SKODA OCTAVIA VRS JABBA'D
CAR SPECIFICATIONS
Engine Type: TURBO
Engine Max Horsepower: 230 bhp
@: 5500 rpm
Engine Torque: 250 lb-ft
@: 1950 rpm
Start Engine Speed: 2000 rpm
with Clutch: DUMP
Number of Gears: 5
Gear Ratio 6th: :1
Wheelbase: 98.7 in.
Tire profile: 55 %
GENERAL PARAMETERS
Starting engine speed: 2000 rpm
Starting gear: 1st
1st 6620 rpm @ 49 mph
2nd 6310 rpm @ 80 mph
3rd 6030 rpm @ 114 mph
4th 5960 rpm @ 144 mph
Time to Speed:
0- 30 mph............ 2.3 sec.
0- 40 mph............ 3.1 sec.
0- 50 mph............ 4.8 sec.
0- 60 mph............ 6.2 sec.
0- 70 mph............ 7.6 sec.
0- 80 mph............ 9.5 sec.
0- 90 mph............ 12.6 sec.
0-100 mph............ 15.3 sec.
Time to Distance:
0- 500 ft............ 8.0 sec.
0-1320 ft.(1/4 mile). 14.6 sec.
@ 97.7 mph
Top Speed............. 152.7 mph
Sub 15 sec Qtr mile now..... not bad, and 150+ MPH top end, nice ;)
Link to comment
May have the power figures wrong, I have 230Bhp and 250FtLb, correct me if I'm wrong, also the RPM that those figures are reached may be wrong... Anyone got a dyno chart of the Jabba setup lurking anywhere?
To do the 4x4 setup I need the figures for it, I assume most is similar to the standard 2wd, but let me know, cause drive ratio's will probably different?
Link to comment
  • 4 months later...
from Skodasnewtoy...
After a lot of time and effort trying to get through to Skoda's Press department that http://www.skodasnewtoy.co.uk options list was incorrect for UK sourced cars, they have removed it from the internet entirely.
At last! :thumbup:
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
