Amundsen MIB2 Firmware Update
4 hours ago, pab567 said:
Then I believe everything is OK and you should not expect any issues.
I realized that I need a battery charger to do the update which I don't have. So this update will wait for some time until I get a battery charger.
Anyway, thank you for your time and update file!
Regards
Svet0
7 minutes ago, pab567 said:
You can make the update while driving or with engine running.
I read it somewhere that the engine must be off while performing the update.
In that case, I will do the update while driving, commuting home takes one hour anyway...
Tnx
Regards
Svet0
The update went well. Took about roughly 15 minutes to finish. Infotainment rebooted a few times.
Got a message about starting a diagnostic test but couldn't start only the cancel button was available so I pressed cancel.
Everything seems to work fine, settings were saved, didn't lose anything as I could test so far.
Updated FW:
Thank you mr. @pab567 for update and help.
Regards
Svet0
Hello @pab567, i have a question that maybe you can answer...  I updated my infotainment (5Q0035874C, HW H41 SW 478) to SW 480 because of problems with wlan connection. It didn't help, but i found that the error was because of the APN of the phone (using ipv6 instead of ipv4). It worked flawlessly until now, but now my infotainment refuses to connect through the phone's hotspot and i was thinking about restoring the older version (478). Can it be done the same way?
I already did, i resetted the system, unfortunately without success. The Infotainment connects to the phone, i can see the connection on the phone and in the infotainment settings on the w-lan page, but there is no connection to the internet through the phone. Hence i cannot connect to the infotainemnt online services. I tried different phones with different android versions, without avail.
You can downgrade from Service Menu / Testomode /. Manual SWDL but you must enable Developer Mode in adaptations first.
