BATTERY IS ALWAYS FLAT
caddyman26
Recommended Posts
Boot lamp on full time?
If it's aftermarket stereo then someone has probably screwed up on the install, just pull the lead from the back to check, if the stereo is the standard fit then it's unlikely to be that unless something is piggybacking on the same feed. Pull a few relevant (lighting) fuses overnight and see if its any better, if not then pull a few other fuses to try and trace the parasitic drain a few fuses at a time.
Link to comment
Share on other sites
Some times the wiring loom on the radio has a connector to swap the ignition feed and constant live... I had this issue with my MK 1 Fabia and a Pioneer head unit, I think it was the yellow and the red wire but don't quote me, this was years ago!!!
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
