Exhaust Inspection Warning Light
Bertha108
Recommended Posts
2016 Yeti 2.0 Diesel 4x4 63k
Without warning, my exhaust inspection warning light came on yesterday. Amber warning and no loss of power (yet).
RAC have been out and done a diagnostic which has shown an EGR & glow plug fault - I'm waiting for the email with confirmed codes.
I have an all component extended warranty with Skoda - does anyone have experience whether they will repair / replace EGR & glow plugs under the warranty please?
Link to comment
Share on other sites
I had that light on, it proved to be no3 glow plug.
I suspect Skoda will say they are consumables.
I replaced all 4 with Bosch OEM glow plugs for just under £10 each.
  • Like 1
Link to comment
What warning would you have liked that a warning light was going to appear ( without warning) on your dashboard?
Edited by J.R.
  • Like 1
Link to comment
I too have all-component extended Skoda warranty (on my 6 year old Yeti);  my reading of the conditions suggest the EGR should be covered,  but I can find no mention of glow plugs,  either in the list of covered items or the list of excluded items.  As has been suggested,  it comes down to what is deemed to be a "consumable" item.  Suggest you have a read of your small-print,  and draw your own conclusions.  (As an example,  clutch components are covered,  except for frictional material,  which I read as release bearing,  slave cylinder etc covered,  friction plate not  (cover plate: anyone's guess!;  likewise brake components are covered,  but not frictional material....which I read as discs covered,  pads not.)
  • Like 1
Link to comment
So somehow you generate friction from the brake pads without pressing them against the discs!!?
Link to comment
Point taken!
Link to comment
Fair point :blush
  • Like 1
Link to comment
The EGR & NOx faults are likely to be expensive fixes.
I would get it booked in with Skoda ASAP, hopefully for a free fix under your extended warranty.
Link to comment
It is booked in now. They can't get me in until 15th though, good job I'm not having to do much travelling. Will see what they have to say once they hook it up!
Link to comment
3 hours ago, Urrell said:
Why no mention of the AdBlue alarms?
Any idea what they mean? I have filled it every time the car informs me it's required.
Link to comment
The reductant injection pump isn't giving the correct feedback to what is being requested by the controller, so bringing up the bottom fault code.
Probably because of that, the two codes above that are being generated.
  • Like 1
Link to comment
I thought that you had done a typo for "reluctant" but now see its yet another meaningless VCDS term, the gift that keeps on giving :sadsmile:
Link to comment
17 hours ago, Wino said:
Adblu is a reducing agent/reductant, so it's not that mad a term to use.
Thanks for that - I'm learning new words about as frequently as I'm 'temporarily misplacing' old ones.
Do you know if they do a reductant for human use?
  • Like 1
  • Cheeky 1
Link to comment
Hi
This is a reminder that Glow Plugs are no longer used just for cold weather starting, but are also used even when the engine is running as part of the (ever more complicated) emissions control system.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
