Lost DAB - Columbus MIB1
Recommended Posts
Hello All,
2015 Octavia vRS, owned for about 4 years faultless until yesterday.
Switched on after being parked up for a few hours and noticed the radio wasn't tuned in, went to change station but all I had was FM, no DAB, the option doesnt even appear.
Columbus MIB1 - It was running 0360, now updated to 0411. Interestingly, in the 0411 update when I look at all of the modules "Tuner" is N/A, no submenu. If I look back at the previous 2015 install on 0360, Tuner has sub-menu for DAB and E2P. DAB was version 197384. However, I can no longer see this with 0411 version.
Media, Phone, Bluetooth, Nav etc are all still working.
Any input greatly appreciated.
Thanks,
Lee
Link to comment
Share on other sites
What can sometimes happen is that the DAB option can be accidently coded out when a firmware update is applied.  The artifaxing from updates can occur.
You will probably need to re-enable DAB - but it would also be a good thing to get a scan of your car to see if the radio is complaining of firmware checksum error (easy to code and fix) or whether the DAB option has been accidently switched out.
Worse case - an hour on ODIS to reenable DAB (about 90UKP)
There is an interesting thread here from Ross-Tech forums:
https://forums.ross-tech.com/index.php?threads/18122/
Edited by varaderoguy
  • Like 1
Link to comment
3 minutes ago, Lee540 said:
Any recommendations for someone in Cornwall or close to that I could use?
Try having a look at this list for VCDS owners to help you out with Scans:
  • Like 1
Link to comment
Thank you. Unfortunately the map is empty in approx 100 mile radius from my location.
I'll give local indy a call. Edit, local VAG specialist not interested..
Edited by Lee540
Link to comment
Great minds.. I've just added the 3 Vin - Hex V2 into my basket.
I have a Mk6 Golf as well as my Skoda so could be a good investment.
Link to comment
Brilliant - in that case - can you get in touch @Gizmo who will add you onto the VCDS register - and you can then look at the numerous mods you can do for your Octavia III -
If you correspond with both @SashaGrace and also @langers2k, they can also assist with VCDS mods.  We will help you understand how the system works.
Many thanks for doing this!
  • Thanks 1
Link to comment
Update to this..
I couldnt figure out the issue. Found a retrofit company/coder about 2 hour drive away.
It appears to be a hardware issue with the DAB controller. EEPROM failure.
On the hunt for a used unit now. 5E0035020
If anyone has one?
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
