can some body help with rear fogs lights and rain close
Recommended Posts
Hi all can someone please help with the coding for my car I'm trying to enable the second rear fog light but I'm not having much luck and also the rain closing for the windows.
I followed this post about the rear fogs but i can't get them to work https://www.briskoda.net/forums/topic/299462-enabling-both-rear-fog-lights-with-vcds-led-cluster/
Wednesday,07,February,2024,15:05:02:01631
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.11.0.0 (x64)  HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: TMBBE7NE9J0284947   License Plate:
Mileage: 87515km-54379mi   Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 03 08 09 10 15 16 17 19 42 44 4B 52 5F A5 A9 D6 D7
VIN: TMBBE7NE9J0284947   Mileage: 87515km-54379miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 P    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---    CVN: FFE2AF15
   Coding: 0C1900122424010B0000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_ECM20TFS0205G0906259P 001001
   ROD: EV_ECM20TFS0205G0906259P.rod
   VCID: 3B233A5D43E5C5223A1-806E
   VINID: 91D49254779525A0022042441CD661CF04
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 CS    HW: 5Q0 614 517 AF
   Component: ESC           H62 0973
   Revision: 00000000    Serial number: 60418000001167
   Coding: 24079391542821704080060440CA2924C92A8402600294762043F070C007430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
   ROD: EV_Brake1UDSContiMK100ESP_037.rod
   VCID: 045181A17E9B7ADA0BB-8050
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5E0 907 044 AP    HW: 5E0 907 044 AP
   Component: Climatronic   H04 2002
   Revision: 00001K00
   Coding: 0111000400011001100500460010102A
   ASAM Dataset: EV_ACClimaBHBVW37X 006147
   ROD: EV_ACClimaBHBVW37X_006_VW37.rod
   VCID: 73B3D27D2B354D62221-8026
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001803900033 Dataset Number: V03935276SP 0001
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 018001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 094F909559B927B278D-805C
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5E2 955 119 A    HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 180120  051 0915
   Serial number: 887253F0401802000027
   Coding: 164DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  047 0105
   Serial number: TBY18M02D16H20M46S16
   Coding: 00885D
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY173132X07
   Alarm horn:
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Component: Sirene, DWA  005 0314
   Serial number: 00002856223973542629
2 Faults Found:
0531 - Footwell Illumination
          B11FF 01 [00001001] - Electrical Failure
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 46
                    Mileage: 87046 km
                    Date: 2024.01.20
                    Time: 17:30:14
                    Terminal 15 status: On
                    Terminal 50 status: OFF
                    CAN-Bus_aktiv: On
                    Status Bremslichtschalter (HW): OFF
                    Status Bremslichtschalter (CAN): OFF
                    OFF: operated
                    Position lamps: Not operated
                    Automatic high beam assist: Not operated
                    Low beam: Not operated
                    Parking light left: Not operated
                    Parking light right: Not operated
                    last_wakeup: gültiges Funktelegramm
                    Voltage: 12.1 V
                    Outside temperature: 6.0 °C
919560 - Light Switch
          B126A 29 [00001000] - Signal Implausible
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 87341 km
                    Date: 2024.01.31
                    Time: 19:05:43
                    Terminal 15 status: OFF
                    CAN-Bus_aktiv: OFF
                    OFF: operated
                    Automatic high beam assist: operated
                    Voltage: 12.1 V
                    Outside temperature: 9.5 °C
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-283.clb
   Part No SW: 5QA 919 283 B    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0044
   Serial number: 000308419618039 Dataset Number: V03935256AE 0001
   Coding: 0601050001
   ASAM Dataset: EV_EPHVA14AU3700000 009033
   ROD: EV_EPHVA14AU3700000_009_SK37.rod
   VCID: 49CF5095193967B2B8D-801C
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 BH    HW: 3Q0 959 655 BH
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W4P1DWN15 Dataset Number: V03935266KC 0001
   Coding: 98CCC000000000005C5400CC008800000065
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 05579CA575A143D21C5-8050
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 454 000 502 18
   Component: SideSensor_Df  008 0887
   Serial number: 3570000000080D84FB2X
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 2 - Part No SW: -----------    HW: 454 000 402 18
   Component: SideSensor_Pf  008 0887
   Serial number: 358000000001BA186C2O
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 3 - Part No SW: -----------    HW: 454 800 102 18
   Component: SideSensor_Dr  301 0148
   Serial number: 351009AEB5613000000P
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 4 - Part No SW: -----------    HW: 454 803 101 18
   Component: SideSensor_Pr  301 0148
   Serial number: 352005FC06513000000E
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 454 802 101 18
   Component: FrontSensor_D  304 0149
   Serial number: 35500AF851C13000000P
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 GD    HW: 5Q0 953 549 F
   Component: Lenks. Modul  003 0140
   Revision: --------    Serial number: 17021804400858
   Coding: 1400
   ASAM Dataset: EV_SMLSKLOMQB 020002
   ROD: EV_SMLSKLOMQB_020_VW37.rod
   VCID: 7EA5F3491077100A5DF-802A
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5E0 920 956 E    HW: 5E0 920 956 E
   Component: KOMBI         303 0310
   Coding: 27AD010069848E00010A6B021001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009060
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 2E0503098097208A8DF-807A
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 L    HW: 3Q0 907 530 C
   Component: GW MQB High   436 4326
   Revision: --------    Serial number: 0007427193 Dataset Number: V03935276GC 0001
   Coding: 030100047F085900FB00026B080F00010001070000000000000000000000
   GVL: 01563C1000000000408C00000000480000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013044
   ROD: EV_GatewNF_VW37.rod
   VCID: 3829255172D3EE3AD73-806C
   Generator:
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000A2892090218
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 J    HW: 5Q0 915 181 J
   Component: J367-BDMConti  H03 1050
   Serial number: 758860000018021525FE
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000113427163  Dataset Number: 5E0222t____ 0013
   Coding: 00150020D001040000001100
   Shop #: WSC 73430 790 00123
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 44D141A13E1BBADA4BB-8010
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000019301939
   Coding: 1D0200
1 Fault Found:
65604 - Door Warning Lamp
          B1326 01 [00001000] - Electrical Failure
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 87341 km
                    Date: 2024.02.01
                    Time: 14:57:34
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 L    HW: 3Q0 909 144 L
   Component: EPS_MQB_ZFLS  507 5081
   Dataset Number: V03935278BB 0001
   Coding: 91170000
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Part No SW: 3Q0 907 338     HW: 3Q0 907 338
   Component: FCM MQB Low   002 0286
   Serial number: 10021810802742 Dataset Number: V03935265KN 0001
   Coding: 000000070100046E00003D01010000000000000000000000000000000000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_MultiModulContiVW48X 001010
   ROD: EV_MultiModulContiVW48X_001.rod
   VCID: 72BDD779542F446A297-8026
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000112829126  Dataset Number: 5E0157t____ 0013
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 43D342BD3B15BDE2721-8016
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000019346783
   Coding: 050200
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 91
                    Mileage: 87151 km
                    Date: 2024.01.22
                    Time: 15:06:06
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 874 C    HW: 5Q0 035 874 C
   Component: MU-S-ND-ER    H41 0480
   Serial number: SKZAZ2U0432698 Dataset Number: V03935278EJ 0001
   Coding: 03735101FF00000041111201008800002F0209D601200500CF
   Shop #: WSC 19460 666 12345
   ASAM Dataset: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 343111616EBB0A5AFBB-8060
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5E0 919 605 M    HW: 5E0 919 605 M
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: SKZ6ZHV0482961
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 820 F    HW: -----------
   Component: ECE1 2023  --- 1910
   Serial number: --------------------
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H07 1272
   Serial number: 09011841K11269 Dataset Number: V03935268CW 0001
   Coding: 0203070100000401000213408150A80094000E200020
   ASAM Dataset: EV_MFKBoschMQBB 001001
   ROD: EV_MFKBoschMQBB_001_VW36.rod
   VCID: 0849959142B35EBA673-805C
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 180120204166
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
   VCID: 698FB01579F987B298D-803C
Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
   Part No SW: 7P5 941 591 AD    HW: 7P5 941 591 A
   Component: LED1L         H06 0005
   ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
1 Fault Found:
0800 - Bulb for Low-Beam Headlamp
          C1198 F6 [00101000] - Over-Temp Protection Active
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 87413 km
                    Date: 2024.02.03
                    Time: 23:48:08
Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
   Component: LED1R         H06 0005
   ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 87413 km
                    Date: 2024.02.03
                    Time: 23:46:47
End----(Elapsed Time: 01:28, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Link to comment
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
