Coolant temperature sensor
Recommended Posts
i’ve had an eml for P0118 - Engine Coolant Temperature circuit high input, however, the temperature gauge has always worked, to try and get the light off i’ve changed the actual sensor and checked the wiring and all seems good, anyone else had this issue, if so what did you do to fix it, cheers
Link to comment
Share on other sites
This code is relating to a temperature sensor used by the engine management system rather than the dash gauges.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
