Automatic Gearbox overheating
Recommended Posts
Hi,
I have an 2021 Octavia 1.5 e-Tec with an automatic gearbox.  On a recent run (100 miles) a warning sign lit up on the dashboard. This was a gear shaped amber light with an exclamation mark inside.  At the same time a warning triangle flashed up.
I checked the gear shaped sign and found that it was something to do with an overheating gearbox.  Later on the journey the sign disappeared.  The next day it reappeared, only to disappear after an hour or so.
If any one can help, I have two questions.
1. Is the car safe to drive?
2. I'm told by the local Skoda dealer that they are "full up" with appointments until July.   Is there an alternative specialist firm that I might contact -  as an alternative to Skoda - who will  be able to fix the problem?
Thanks in advance.
Tico
Link to comment
Share on other sites
I suggest you look up some local independent specialists. If you google "independent skoda specialists" with your area, you'll get a list of suggestions
tell them about your issue and see what they say about it being drivable
Link to comment
Thank you for the suggestion. I'll do that straight away.  Regards.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
