Are mixed width tyres (225 front/ 205 back) wise?
sixman9
Recommended Posts
Gentlemen,
Although I'm 'reasonably' well paid, I don't want to fork out on a full set of tyres at the moment. However, my rears are now balder than the proverbial eagle (?), so I must now purchase replacements. The present set are 'standard' Octavia vRS size (205/17"), but I'm considering moving to 225/17 because they offer more grip and are easier to come by, I'm lead to believe.
Would it be at all wise/OK to say swap my current fronts to the rear (205/17's) and put some new 225/17 at the front end, until money stretches far enough to complete the 225 set (or the current set ALL wear out)? I'm no expert but I'm wondering about the cars dynamics etc, or is this a total No-No?
Big Rich.
P.S. No flames, pretty please :rolleyes:
Link to comment
Share on other sites
I was told by a tyre fitting company years ago that it was illegal to have wider tyres on the front of a vehicle then the rear as I was in a similar situation with swapping tyres etc. I don't know whether this is true but it might be worth ringing your local independant tyre stockist and ask there opinion. I also may have a set of vrs alloys with original tyres for sale soon (see post on RS4 alloys)
Link to comment
Stick the new tyres on the rear anyway as the fronts will wear quicker. When you then come to replace the fronts, the new larger rears that are already on will be barely worn
Link to comment
Quite sadly, I've made a spreadsheet to calculate at what point to swap the rear tyres to the front and vise versa such that all tyres need replacement at the same time. I did have a nasty experience with different tyres front and rear though.
Link to comment
Thanks for that gentlemen. So I'm taking it is IS OK to go with the new 225's at the rear. It's worrying that at least one of you had an issue with larger rears, but the wear and tear of the old 205's at the front makes a lot of sense :D
Now just to see if my neighbour can get me a nice discount at A-national T-yre S-hop :thumbup:
Big Rich
P.S. Costco do Michellin [?] Pilot Sport [Contact, ?], 225/45/17's for
Link to comment
You should ALWAYS fit new tyres to the rear, the old addage of new on front because of wear has been proven in many tests to be extremely dangerous because under extreme conditions, eg. hard braking in emergency or cornering quickly with the worn tyres on the back the rear end has a tendancy to overtake the front of the car.
My old BM had 245's on the rear and 225's on the front and seemed to stick to the road like glue. You cant fit them the other way round, not only is that dangerous but you will also fail the MOT when it is due.
Link to comment
new tyres should be placed to the rear of the car, you want the best tread at the rear as you have no control over the rear axle... the front tyres could be near on bold but you can still control them. 225 45 17 will be ok on the rear and i would let the 205`s scrub out on the front. i would only recommend swapping tyres front to back but keeping them on the same side...i.e nearside front to nearside rear do not be tempted to swap them side to side.....if you think about it a tyre that has done say 5k going in one direction is then turned the other way uneven tyre wear can result and also vibration problems can occur
personally try Goodyear F1`s they are quiet and oh so very sticky
need more info on tyres call me
Phil
Link to comment
sorry but as long as the tyres are on the same axle it wouldn`t fail the MOT....
size and profile the same it would only warrant an advisory...
Phil
Link to comment
according to a good friend of mine who happens to work for national tyres it is infact illegal or at least you could get a ticking off for having wider tyres on the front of your car than the back.
I'd put the new wider tyres on the back and the thinner ones on the front, you should have enough tread on the front to last 6-12 months then and when you swap them for the same size as the backs you can swap them around again.
apparently its also recommended you bed tyres in on the rear.
Link to comment
HI...all tyres front or rear should be bedded in we normally advise 30-50 miles although my F1`s took about 200 before they fealt good
wider tyres on the front only become illegal if they foul or protrude the body...i admit though you should never have wider tyres on the front than back.cos it looks stupid:rofl: dont forget it might pass an MOT but it may be a police legalisation....
:thumbup: Phil
Link to comment
You should ALWAYS fit new tyres to the rear' date=' the old addage of new on front because of wear has been proven in many tests to be extremely dangerous because under extreme conditions, eg. hard braking in emergency or cornering quickly with the worn tyres on the back the rear end has a tendancy to overtake the front of the car.
My old BM had 245's on the rear and 225's on the front and seemed to stick to the road like glue. You cant fit them the other way round, not only is that dangerous but you will also fail the MOT when it is due.[/quote']
That explains my 'exit stage left' incident then when the rear most certainly overtook the front. Will bear that in mind from now on!
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
