Fabia performance upgrades - recommendations please
Hi
I'm upgrading my Fabia VRS (55 plate) - already had it chipped to 180bhp at High-performance vehicle tuning, ECU remaps, Exhausts and Styling
I now want to upgrade various other components and wanted some recommendations (btw I've not got unlimited budget - so want a balance between quality, price and performance)...
If you could help me could you recommend upgrades for:
1 - Suspension
2 - Exhaust
3 - Brakes
4 - Clutch
5 - Airfilter
6 - Wheels (17 or up)
7 - Anything else I've missed...
Any help appreciated!
Cheers
therealgiblet
Hi
1 - Suspension
2 - Exhaust
3 - Brakes
4 - Clutch
5 - Airfilter
Cheers
therealgiblet
1.koni and eibachs
2.miltek
3.312mm brake upgrade
4.sachs organic clutch
5. green filter or pipercross
6.17inch MK1 oct wheels
7.Jabba ARB and PD160 air intake
1 - Suspension
Eibach springs, Koni FSD shocks, Jabba Rear anti-roll bar, ibiza cupra wishbone bushes, front upper strut brace
2 - Exhaust
Milltek or Blue-flame are the only options really
3 - Brakes
VAG Group 312mm brakes from audi TT, Leon, Octavia vRS etc.. new calipers, carriers, discs and pads can be had for just over £200 on ebay
4 - Clutch
Sachs organic clutch the popular choice, retains the standard flywheel
5 - Airfilter
Pipercross or green filter, Ibiza Cupra PD160 intake pipe upgrade
Whatever takes your fancy, 18" difficult to make fit
for bigger power? FMIC, pikey mods. etc
HTH :D
Thanks guys - that was a quick response :)
There's a lot to think about there!
Do you recommend any suppliers or should I just search the interweb?
Cheers again
get as much as you can off the for sale secton on here,then hunt round e bay,fit it all yourself and you have built a sweet performing motor for pennies:D
if you have to have it all new look under the site sponsors,they can provide everything you need:thumbup:
Jabbasport.com, try and get on a group buy, theres often ones running and they save you a bundle!
As for 312mm brake kits for £200 on ebay, i wish! i look on there every couple of days with no luck. £295 is the cheapest you will get, do a search on google, theres a guy on here that sells them.
Just get a custom backbox and straight through pipe for you exhaust option ;)
There is no piont in fitting any sort of high flow/race cat.
You can probably get that lot for less than £200 fitted.
This might be a contentious answer but......
I have a modified Fabia vRS and the mad wife has a standard Fabia vRS.
We both drive in a spirited manner, and drive each others cars regularly.
After discussing modifications we are agreed that the ONLY ones needed are the rear arb and uprated front brakes.
£500 or thereabouts.
Sorted.
