Octavia II Useful Part Numbers
I've created a list of some part numbers for common parts on the octy II.
Please note all part numbers should be checked with the dealer/supplier before ordering as parts may be vehicle specific.
Common:
  • Space saver spare wheel (without tyre) - S 1K0 601 027 K03 C
  • Centre cap for pegasys alloy wheel (each) - 6u0 601 151 LMH B
  • Rear Wiper Blade - 1k0 955 429 A
  • Estate Rear Wiper Blade - 7E0 955 425
  • Aero Wiper (drivers side) - 1Z2 955 426 A
  • Fuel Filler flap (Primed) - 1Z5 809 857 F
  • 312mm (VRS) Front Brake Disks - 1K0 615 301 AA
  • Extinguisher Holder - GCA 600 001
  • Fire Extinguisher - GCA 000 001
  • Stainless Sill Covers - KDA 600 002
  • Carpet Mats (Black) - DCA 600 102
  • Front Mudflaps - KEA 600 002
  • Rear Mudflaps - KEA 600 001
  • Dash trim for MFD2/3 with Climatronic (black) - 1Z0 858 069 C 9B9
  • Dash trim for MFD2/3 with Climatronic (silver) - 1Z0 858 069 R 2AU
  • Dash trim for MFD2/3 with Climatronic and phone cut outs (silver) - 1Z0 858 069 Q 2AU
  • Dash trim for Stream/Stream MP3 with Climatronic (black) - 1Z0 858 069 A
  • Dash trim for MFD2/3 for VRS LE and FL Octavia with New style Climatronic. - 1Z0 858 069 BK 2AU
  • Single DIN Radio Adaptor kit - AZO 600 003
  • Speaker trim (tweater, drivers door) - 1Z2 867 4369 B9
  • Boot Hook (Hatchback) - DMA 610 007
  • Underseat storage box (RH seat - Onyx) - 1Z0 881 578 E 47H
  • Underseat storage box (RH seat - Ivory) - 1Z0 881 578 E 4K1
  • Wheel nut cover - 1Z0 601 173 Z37
  • Wheel nut cover (locking nut) - 1Z0 601 173 A Z37
  • Under bonnet sounds insulation sheet (As found on diesels) - 1Z0 863 831 A
  • Improved design engine cover grommets - 03G 103 184 C (note this is a single grommet)
2.0 TDI
  • Oil Filter - 071 115 562 C
  • Air Filter - 1K0 129 620 D
  • Pollen Filter - 1K2 319 652 B ( Charcoal Type)
  • Fuel Filter - 1K0 127 434
  • Sump Plug - N90 913 202
1.9 TDI
  • Pollen Filter - 1K0 819 644 B (Standard type)
  • Sump plug - N90 813 202
  • Fuel Filter - 3C0 127 434
  • Front Brake Discs - 1K0 615 301 AC
  • Front Brake Pads - 1K0 698 151 A
  • Rear Discs - 1K0 615 601 AB
  • Rear Pads - 1K0 698 451 J
  • Brake disc screws - N10 648 301
  • O/S/F Hub Assembly - 1K0 407 256 P
  • Hub Bolt(strut to hub pinch bolt) - 1J0 615 219
2.0 TFSI
  • Diverter Valve - 06H 145 710 D
  • Coilpacks - 07K 905 715 F
  • Air Filter - 06F 133 843 A
2.0 FSI
1.8 TSI
Related Guides
Extinguisher fitting guide:
http://briskoda.net/forums/topic/88620-octy-ii-fire-extinguisher-how-to/
Storage box fitting guide:
http://briskoda.net/octavia-ii/how-add-underseat-storagebox-pictures/78479/
Feel free to update this list as and when you have part numbers.
Edited by cheezemonkhai
Added additional part numbers
  • Replies 134
  • Views 140.9k
  • Mudflaps, that will fit the vRS even though all dealers seem to tell people otherwise Front Mudflaps KEA 600 002 Rear Mudflaps KEA 600 001 Should be around £20 a pair. Boot hook for the hatch.
  • WaveyDaveyGravy
    WaveyDaveyGravy
    Missed a number off that - it's 1Z0 863 831A - superceded the non-A version. Also 1Z0 949 102C - drivers side mirror indicator 1Z0 857 538A GRU - drivers side mirror cover (primed)
Anyone got any part numbers for the VRS or 1.9 TDI's?
I'll amalgamate everything into the first post and keep this thread tidy, might even stick it if it becomes worthy :)
Unfortunately i have rather a collection of part no's :(
For TFSi
06H 145 710D for Diverter Valve
07K 905 715F for Coilpacks (don't know if they are same across all petrol engines) Courtesy of Wardy
Carl:thumbup:
Thanks Guys, I've added them to the first post for clarity.
Don't suppose you have any of them around that you fancy sharing when you get some time?
Mudflaps, that will fit the vRS even though all dealers seem to tell people otherwise :D
Boot hook for the hatch. There should be one on the left, but another can be popped in on the other side.
DMA 610 007, about £6.
Steve
Estate Rear Wiper Blade - 7E0955425 - Approx £4.75 + VAT
Speaker trim (tweater, drivers door) - 1Z28674369B9 - Approx £3.35 + VAT
Aero Wiper (drivers side) - 1Z2955426A - Approx £12.00 + VAT
Single DIN Radio Adaptor kit - AZO600003 - Approx £39.00 + VAT
I do have a picture of a exploded diagram of the rear suspension setup including the eccentric bushes. With the part no's listed if thats of any use?
If it includes part numbers that you think would be parts people might order from time to time then by all means post up the part numbers and a brief description
Specifically interested in air and oil filters for the VRS and 1.9 TDI, so if anyone has these it would be much appreciated if you could post them here.
Ta
vRS Petrol Airfilter is 06F133843A (I've gotten the number from 2 sources but haven't actually got it yet :thumbup:)
Hi, has anyone got the pert number for the MAF sensor for 2.0tdi (BKD) ??
Here's the photo of the rear suspension diagram.
29783.attach
Hope this helps
Anyone got the Pt Number for the little mesh cargo net the covers the little cubby storage compartment at the drivers side rear of the boot. the plastic brackets have smashed off mine :(
Ta
After service today i have got many part numbers for 1.9TDi items as follows:
Sump plug - N90813202 - £1.14
Air Filter - 1K0129620D - £11.86
Oil Filter - 071115562C - £5.20
Pollen Filter - 1K0819644B - £7.28
Fuel Filter - 3C0127434 - £21.06
Front Brake Discs - 1K0615301AC - £36.04 each
Front Brake Pads - 1K0698151A - £38.00
Brake disc screws - N10648301 - £0.19 each
O/S/F Hub Assembly -- 1K0407256P - £160.39 :eek:
Hub Bolt(strut to hub pinch bolt) - 1J0615219 - £14.08 :eek::eek:
All above prices are excluding VAT
Soundproofing pad for the underside of the bonnet.
Part No. 1Z086383, Description "SOUND ABSO"
Price: Ask darrenw.
It seems the Silver Columbus dash trim in the Octavia vRS FL is different to the trim in the vRS LE. The above part number is for a trim with a flat/matt silver finish to it.
The Silver Columbus dash trim in the vRS FL is a light tonal brushed trim and is one of the following part numbers:
1Z0 858 069 DK DF1
1Z0 858 069 DL DF1
I am waiting on confirmation from the factory as to which one it is, I will post up here when I find out.
Hope this helps :)
Octavia Vrs LE Wheels 18" Monza R Hi Power Silver
Wheel ZGB120071499
Centre Cap ZGB120071491
Improved design engine cover grommets (52p each, 6 in total on a PD170)
03G 103 184 C
WARNING!!!
Dash trim for MFD2/3 with Climatronic (silver) - 1Z0 858 069 Q 2AU
This part has got cut outs for phone preparation!!!!
Please use 1Z0 858 069 L 2AU
Also this is only for vehicles with navigation system
or 1Z0 858 069 R 2AU - that's identical to L 2AU
Spare Wheel Tie Down - 1J0 803 899
The best way to describe it is a large plastic grip with a M5 x 10cm steel bolt in the centre of it.
