PD170 Stuttering Problem solved
As most of you know ive had a stuttering problem for ages (Well since DPF Removal), It does it mainly when launching from a roundabout or traffic lights in 1st and 2nd gear and then when on motorways when accelerating in 5th and 6th.
Ive read about a fix for PD130,PD140,PD150 & PD160 Engines so ive tried it out on the PD170 and it seems to have fixed it :D :D :D Been for a 40 minute drive since and not been able to replicate the stuttering
So whats needed:
1x Part Number:028131547B (£2 From Dave @ SERE Motors)
1x T50 Torx Bit
Below is the original Gasket (Top) and New Gasket (Bottom)
And this is where the old one came from and the new one is going
Basically all as you do is remove your engine cover and undo the two T50 Bolts off the metal pipe! Pull the pipe away from the EGR, Mine was stuck so i used a biggish screwdriver to do it,My old gasket was also stuck on so i also used a smaller screwdriver to pull that off the pipe and remove it.
Slide the new gasket in and fasten it all back up
Takes literally 5 minutes :D
As i said it seems to have solved mine! Not been able to replicate it but im not promising it will fix everybody's but for £2 its worth a try
Edited by AndrewJB
What have you done to get 235bhp from your PD170 ??
DPF Removal, Milltek Cat-Back, Panel Filter and Custom Code Phase 2 DPF Delete Remap
Has anyone removed their DPF on their common rail vRS yet? If so what gains / improvements?
Are Miltek selling a delete pipe direct yet?
Edited by jcdub
Not sure really CR doesnt suffer with same problems as PD
Nice one buddy, the stutter was putting me off getting my dpf removed, well done :thumbup:
Some standard PD140 and P170's have the problem aswell tho
But mine started doing it as soon as the DPF Was removed, If thought up an explination for this dunno how true it is tho :giggle:
Basically my theory is..... Because the DPF is removed obviously the exhaust gases are more sooty so the engine is chocking on them when the EGR Kicks in
By restricting it with this Gasket its only getting the original amount of Chokey gases now like when the DPF was there
Thats my theory anyway :giggle:
  • 7 months later...
Ben is it a mapping Fix?
Yes it is, from now on all our maps will incorporate this fix :thumbup:
Shame Custard Codes wont :thumbdown:
Oh well mine doesnt do it that much anymore maybe once a month
Edited by AndrewJB
Well, you know where we are for the future :thumbup:
The most important thing is that it can actually be fixed :)
out of interest is it something that VAG Should be applying to standard cars because as we know Standard cars have the same problem, and not just the PD170 seen it on PD140's aswell
Well, if we can fix it then they should be able to. But the PPD ECU wasn't used for very long, probably due to the amount of problems they had and number of software updates etc.
Big Update
Today ive removed my EGR Valve and fitted a Roadsport kit made by Darkside Developements (Similar to the one Allard Make)
I took it out for a 20 minute drive, With a mixture of town driving and pure hard driving and so far, Ive not managed to make it stutter at all, Also so far no warning lights
With the Reducer gasket fitted before it would still stutter but not half as much as it did standard
I will report back after the weekend as im driving from Milton Keynes to Scotland (5 hours on M1 and M6) So if its going to stutter it will on that drive
Edited by AndrewJB
Did it solve your stutter then mate? I take it this is like a blanking plate?
Yes it has car hasnt stuttered but no its not a blanking plate its a full EGR Delete kit
So whats needed:
1x T50 Torx Bit
[/b]
Is this a Skoda part number or a Seat part number? Thanks
SEAT off a MK3 Ibiza
Nice one, thanks
I'm struggling to find details on their website..can you shed any more light? Like how much? Does it work? Etc.
I have reached the conclusion that JBS don't give a cr@p once they've had your money!!
