Rear tyre wear
I have a Skoda estate (2011 model) and I am having trouble with the rear tyres in that the are wearing (castlated ?)
Will four wheel alignment solve the problem
Coincidentally, my mate is having the same problem with his
Any thoughts ?
Edited by shaun h
Its a known issue. A forum search will give you the correct values.
Also known as saw toothing
Tyre pressures play a big part, but adjusting rear camber to 1deg 20 mins negative on the back should help.
But why has this issue returned after Skoda sorted the issue back in 2007?
