Another rattle thread
Seeing as the weather has been a lot warmer recently, has anyone else experienced the following...
Around 1k-2k revs at low speeds and when pulling away there is a clear rattle that I cannot seem to locate. There was a mention of the fuel pipes in the conduit at the RH back of the engine bay being unsecure a while ago and also the clutches in the gearbox a la a Ducati dry set-up. The noise appears to exaserbated by heat.
Car seems to behave completely normally so am hoping it will be cured when in for its service due to 'simply' being a pipe or similar.
Is it just the well documented 'cattle grid' noise that some get from the DSG ?
Are you aware of it in the hot weather because you have the window open?
Plenty threads on it from this section of the Forum.
http://briskoda.net/forums/topic/312147-rattle-please-help
Has your car required & had the Service Campaign Field Action on the DSG,
Synthetic Oil changed to Mineral & a ECU update for the DSG?
