Remap / chiptuning available for the 2.0tsi VRS!
The DQ381,s do not have proven reliability or longevity yet.
Actually they are showing as being possibly troublesome.  Running one without a warranty needs to be taken into the equation.
  • Replies 89
  • Views 27.2k
  • Are you sure it's DQ381? 381 is meant for 4x4, vRS is FWD, so it should have 380. Anyway of course all of those numbers are given with some tolerance. As far as i know in reality DQ200 is ok up t
  • Mario_Delgado
    Mario_Delgado
    And today was my day 🙂, results in line with the ones from @DutchVRS, I am getting 324,1 HP at 5372 rpm with 492 Nm at 2850 rpm. I would say I have higher torque values due to the fact that I did DSG
  • I don't either to be fair, I've just over a year to wait for my warranty to run out anyway so hopefully any pros and cons will be better known by then.
Surely this is an improvement on predecessor with lessons learned and improvements made? Not heard of any troubling issues with these as yet...like any "auto" box depends how you treat them I guess
@Jamster330
I imagine that those remapping intend to give them welly at some point and are not just doing it to improve the economy.
Sadly VW Group appear not to have learned, but maybe they will reduce the service interval eventually and include the filter,
and maybe even put a decent warranty on them.
You maybe need to look in other sections of this forum.
http://briskoda.net/forums/topic/508475-gearbox-dq381-in-emergency-mode
These are AWD's but the issues are not only with them.
http://briskoda.net/forums/topic/509581-7-gear-4x4-dsg-gearbox-error-codes-for-a-2018-tsi-kodiaq
http://briskoda.net/forums/topic/509101-dsg-in-emergency-mode-in-the-cold
http://briskoda.net/forums/topic/502781-gearbox-in-emergency-mode-no-reverse-gear
http://briskoda.net/forums/topic/505394-gearbox-oil-leak
http://briskoda.net/forums/topic/510461-what-dsg-box-do-i-have
Edited by toot
29 minutes ago, toot said:
@Jamster330
@toot
Thanks for the v useful info and links as I intend to be keeping the car for quite some time I'll be looking to get DSG oil/filter change done at 4 yrs as opposed to the recommended 8!!
I dont tend to welly the car too much but do like the idea of having an extra bit of power ... always ensure that both engine / gearbox oil are nicely warmed up
Interesting. Thank you.
Maybe of interest to those with remaps and using 97 min or 99 min E5 in the UK from the various petrol retailers with E5..
340214144_1384336435_Screenshot2022-01-3014_03_59.jpg.d43b66a38bf086423e31cbd1b02722b8(1).jpg.dce3a2706e11f7c315d6b050e3a54835.jpg
Edited by toot
  • 4 weeks later...
Looks like APR are in on the act too now https://www.goapr.com/blog/post/apr_2022_vw_gti_mk8_ecu_upgrades_are_here_us_ca_/ unclear if it's just North America however?
On 10/11/2022 at 20:54, TheUltraRunner said:
What's the other car?
Tuned 550i
5 minutes ago, Boosted_8 said:
Tuned 550i
Better late than never. ;) Nice ride btw! 👍
@TheUltraRunnerThanks mate. I forgot my old account details hence the long absence and new user name :)
On 27/12/2022 at 17:38, DutchVRS said:
I remapped last week😁😁
So, I remapped a couple of months ago with Phantom Tuning.
 How have you found the remap?
I’m well impressed with the performance gain. Economy is a little better.
3rd & 4th are insane!
I really wanted the gains for 3,4,5 & sixth gears.
Bearing in mind it wheel spun in first & seconds anyway, I’m not interested in launching. (Mines manual)
If I get the timing right, she’ll still wheel spin in 3rd!!
 The one thing I would like to know, is do you have a quiver at 2,000rpm ish? Especially in the higher gears if you floor it?
That could be due to the calibration asking for 100% wastegate duty when full throttle is demanded at lower RPM. This is basically to get the turbo going and move air as demanded by the go pedal. From tuning my own cars with Cobb access port, I could produce a stutter like you describe at under 2,5k rpm resulting from an over boost situation, the ECU responds by flicking the throttle body to half shut a few times in that split second to slow the huge wall of air coming in. I don't know if your map has boost by gear but you usually feel this happening in 3rd or above as it happens too quickly in 1st and 2nd to detect as well as often being boost limited in FWD maps.
Yeah, it’s mainly in 4th, 5th & 6th, most noticeable in 6th. It’s mainly me being lazy on the motorway and not bothering to down shift. I only let it do it a couple of times thinking it might have been road surface or something but then realised so I don’t let it happen anymore.
 Thanks for your insight. 👍🏼
Just a general one, If it's a manual with no kick down, it's kinder to your connecting rods to drop a gear rather than asking for heaps of torque at low rpm. Modern ECUs will protect the engine from det, but it's still the worst kind of load as the most ignition advance is occuring at about 2k rpm partial throttle.
